MP 4000 and 5000's not accepting static IP.
  • nmfaxman
    • 1702
    Ran into one that I thought was kind of a fluke.
    Set up for DHCP machine works fine.
    As soon as I put in a static IP the NIB basically shuts down.
    Can't ping, telnet, ping out and SMTP server connection fails.
    Was wondering if anyone else has run into this.
    I prefer to network the machines as static so IT has less problems.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MP 4000 and 5000's not accepting static IP.
    Not seen it myself, have you tried doing a memory clear on NCS / NIB?
    • nmfaxman
      • 1702
      That was the trick I was looking for.
      • techsass
        • Dec 2010
        • 248
        The only thing I've run across similar to this is when the tech enables WiFi. It basically disables the NIC.
