Scan Confirmation Print-out
  • AndreLouw
    • Aug 2025
    [Misc] Scan Confirmation Print-out
    Hi ALL
    I have a request to activate a print-out after every scan-to-mail.....this is for legal proof that the scan was sent to an e-mail. SAMSUNG has this feature, i can't seem to set MPc401 to perform this function. When you print a JOURNAL, it only indicates DATE,TIME,E-MAIL address and COMPLETED....not how many PAGES were scanned...
    Can someone plz advise of any settings i can program?
  • nmfaxman
    • 1702
    Re: Scan Confirmation Print-out
    Can't even see scanning in the job log in WIM.
    My suggestion is to send a duplicate with the cc to themselves.
    It will show date and time and the pages.
    At least it saves on paper.
    • ruben
      The New Guy
      • Oct 2012
      • 1204
      If they need "legal" proof that an email was sent they should print off a transaction report from their email server, not the copier. The copier does not know if the email was recieved, in fact no one does, so I cannot see how this is legally binding. For fax, which is a direct connection (or at least most of the time, i.e. man in the middle) this could be true, but everyone is moving away from that legality.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Exactly.
        All the copier knows is that the scan made it to the SMTP server - it has no idea if the final destination was ever reached.
        I like the cc idea. It may not be legal proof either, but it is a good indicator of sorts. It will also show if pages stuck together, got scanned upside down (blank) etc...
        • nmfaxman
          • 1702
          For verification of reception use reception notice on control panel.
          Make sure they are the sender.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            GlobalScan, either Server or Serverless, will provide a bit more info.
            Not free, but not terribly expensive, either.
            In this case I would think Serverless would be a better fit, although Server will also give them OCR, which is not available in Serverless (due to the higher resource utilization).
