MP5200s Config link in WIM comes up with cannot load page
  • drwevil
    • Nov 2013
    • 53
    Hi Yall
    I have 2 possibly more SP5200s at the same customer that when you try to load the config page you get "Page Cannot be loaded - server terminated connection" error varies a bit depending on browser.
    The machine functions normally in all other respects other than @remote cannot be setup ... not sure why as I cant get into Config in WIM
    Firmware is up to date.
    tried multiple browsers and PC's.
    Yes I have logged in. Actually if you don't log in config link works as it should.... ie displays info.
    All other links work.
    I haven't tried connecting my laptop yet.
    I seem to remember there is a way to lock users out of parts of WIM but I have checked the manual and all the settings I can find are set to defaults.
  • CRISTIAN MULLER
    • Feb 2013
    • 145
    Re: MP5200s Config link in WIM comes up with cannot load page
    Originally posted by drwevil
    Hi Yall
    Try to disable "proxy" on Preferences of your Browser, maybe proxy are enable to internal destinations also.
      • 37489
      I have been kicked out of WIM on some models by the machine entering energy saver and by some at the machine entering User Tools.
      • teebee1234
        • 1670
        Maybe this?.........
        Unable
        to display Web Image Monitor page
        Print Notify Me
        Published 01/16/2008 10:47 AM | Updated 01/21/2010 08:43 PM
        Answer ID 78251 | FAQ ID 103013 | Rank A0
        I am unable to display the Web Image Monitor page for my device, but am able to Ping and Print to it. What can I do to fix this?
        [Permit SSL/TLS Communication] may be set to [Ciphertext Only] (Allows encrypted communication only. If encryption is not possible, the device does not communicate.).
        Note: [Ciphertext Only] is defaulted to when [Network Security] [Level 2] is selected in [Administrator Tools] page 3. When selecting [Ciphertext Only], a server certification is necessary for communication.
        [Action]
        1. Press [User Tools/Counter] key.
        2. Select [System Settings].
        3. Select [Interface Settings] and Press [Next] to scroll down to page 2.
        4. Select [Permit SSL/TLS Communication].
        5. Select [Ciphertext Priority] or [Ciphertext/Clear Text] and press [OK].
        6. Press [User Tools/Counter] key to exit.
