I have an AF 1022 that is driving me crazy!
It will intermittently stop with the paper (LEF) halfway stuck in the fuser.
I have checked/swopped the following:
The drive assembly to the fuser (swing gear had damaged teeth) including the solenoid.
I checked all the clutches down the paper path including registration relay and tray clutches.
I have removed and cleaned the exit section and interchange unit (machine has duplex and bridge plus finisher). This includes all the solenoids.
Everything in the fuser is 100% (gears, bearings, etc.
I need to regain my sanity!
