I'm doing a favor for a amall church that had a copier donated to them
  • Rickygib
    • Aug 2025
    [Error Code] I'm doing a favor for a amall church that had a copier donated to them
    Savin c2525/Ricoh Mp2500 Error Code SC535
    I've searched all over for a resolution to this Error code and have yet to find an answer. I'm doing a favor for a small church that had the copier donated to them. I hope someone can help me get it working again.
    Thanks in advance,
    Ricky
  • Ben Around
    • Apr 2012
    • 151
    Re: I'm doing a favor for a amall church that had a copier donated to them
    Thanks in advance,
    Ricky
    I couldn't find SC535 in the MP 2500 manual. But the MP C2500 says this:
    PSU fan 1/2 error
    The BICU does not receive the lock signal 10 seconds after turning on
    the PSU fan 1/2 motor.
    Defective PSU fan motor 1/2
    1. Replace the PSU fan motor 1/2
    Sounds like a bad fan, look for a stuck fan in the pwr supply area. I've revived them with a few drops of oil on the shaft.
    • Rickygib
      PSU fan 1/2 error
      Thanks "Ben Around"
      I'll try and locate a service manual to make sure I'm looking in the right place. I really appreciate your time and your effort.
      Enjoy your weekend.
      • Polarbear
        • Feb 2012
        • 1070
        Hi
        There is no code like that in the 2500 manual. Are you sure about the code?
        Please check back and I can look it up for you if it turns out to be a different code.
        Cheers.
        Press the GREEN button!!
        • Nutstar
          • Mar 2011
          • 110
          Thanks in advance,
          Ricky
          have had a 535 error on an MPC2500 before, cannot for the life of me recall what the fix was, we did get it fixed though!
          if it's any help it's in the fixing area but there is another thread on here that goes:
          fuser fan, input output, power supply, in that order of parts required, on the provision that you've checekd the fan and its deffo not causing the problem.
            • 37560
            PSU fan is item 6 on the attached. There are two of them, one on each side.
