Authentication Fail - MP C4500
+ More Options
Posts
  • ABS tect
    • Sep 2013
    • 511
    Got a refurbished 4500, I would really like to use the machine, everything works great except I cannot get into the machine because it asks me for a login user name and password to get into anything on the "user tools" settings. And I can't change the IP address since i can't get into system settings. Does anybody know a way to get past this? Thank you
  • Elmo
    • Feb 2010
    • 541
    Re: Authentication Fail - MP C4500
    Try Admin no password or Supervisor no password
    the supervisor will let you change the admin password
    there are plenty of threads on this matter
    I Used To Live To Fix Things Now i Fix Things To Live
    • ABS tect
      • Sep 2013
      • 511
      Right...I know how to do this from the web image monitor, but i can't even get into that without knowing the IP address of the machine. And when i go into user tools to hit "system settings" it makes me log in. So i have to get through that to change the password.
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        Unless the admin login has been changed, you can login under User Tools (button is top right) with the default login credentials. You can then remove the requirement for an admin login under System Settings -> Administrator Tools -> Administrator Authentication Management.
        • ABS tect
          • Sep 2013
          • 511
          Right...I know how to do that from system settings, it's just that it requires a login user name and password to get into system settings, this is what I need to get by. Any ideas? I used several combinations for the user name and password (admin, administrator, supervisor, etc.)none of them have worked. Anything I can do to the print card to fix it maybe?
            • 37481
            You are either going to have to replace or edit the NVRAM. There is a post on how to edit the NVRAM on the forum somewhere. Just do some searching.
            • tjvincent
              • 280
              Turn on S.P. 5055 to display I.P. address
                • 37481
                Originally posted by terramobil
                You can use Ricoh Smart Device Monitor to figure out the IP Address, or use SP 5-801 to reset the device to factory default.
                SP 5801 does not reset to factory default. SP 5801-001 clears all memory, including those settings made at the factory.
                • NeoMatrix
                  Senior Tech.
                  • 3513
                  Search CTN for skynetto's password reset tool.
                  If you can't find it I have it here somewhere.
                  Search CTN for "A new tool for helping techs" or just "skynetto".
                  You may have to get an updated version from Skynetto.
                  HTH
                  • ABS tect
                    • Sep 2013
                    • 511
                    Thank you! SC 5055 allowed me to see the IP address which then allowed me to go into the web image monitor and I was able to turn off the authentication from there.I know the SC5801 can definitely cause some trouble, especially if you don't have the birth certificate so I would stay away from that if possible or as a last resort. Thanks for all the advice.
                      • 37481
                      If you could get in to turn off Administrator Authentication with WIM, why were you not able to do so from the front panel?
