MP C2003 Black does not dolid image
  • PA3040
    • Jun 2014
    • 171
    DearAll
    We have MP C2003 ( Metis yz) machine, it does not properly transfer black image and text ( no solid black).
    we sow using magnifier glass then we can see that some dots does not transfer to the paper. we does not see this issue for other colors
    Copy volume 3752
    Driver used PLC6 and 5
    Papers= any papers has this issue
    we checked K image transfer roller ...no issue
    Please advice
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: MP C2003 Black does not dolid image
    Off the top of my head.
    1. Check the transfer unit lever is fully engaged in the down position.
    2. Check the paper weight/thickness is correctly specified on the MFD and print driver for the paper being used.
    Thin (52 to 59 g/m2)
    Plain (60 to 81 g/m2)
    Middle Thick (82 to 105g/m2)
    Thick 1 (106 to 169 g/m2)
    Thick 2 (170 to 220 g/m2)
    Thick 3 (221 to 256 g/m2)
      • 37510
      If this is only in copy and not in printing, run Auto Color Calibration.
      • PA3040
        • Jun 2014
        • 171
        Dear Cipher,
        Thanks for the reply
        We used correct paper type and also we checked the image transfer lever for black, which is correctly located and we make some changes manually by applying force to the lever,but it not helped. we further observed that this issue heavily affected for black text and adages
        Please advice
        • Imprestik
          • Aug 2012
          • 297
          Are the copies washed out on the black only?
          Has someone recently replaced the Black PCU?
          I bet you the earth plate on the back of the PCU is missing
          • PA3040
            • Jun 2014
            • 171
            444973]Are the copies washed out on the black only?
            Yes only black
            No, This is new machine copy volume less than 4000
            I will check this and update but I assume it is impossible sine this is brad new machine
            Please advice
            • PA3040
              • Jun 2014
              • 171
              This is happening printing too
              • Cipher
                • May 2006
                • 1309
                Have you a sample that shows the issue clearly that you can post?
                • PA3040
                  • Jun 2014
                  • 171
                  Dear Cipher,
                  For better view please download the image and enlarge, then you can see black wash out of the text
                  Please advice
                  • Cipher
                    • May 2006
                    • 1309
                    Looks like insufficient fusing / the toner is lifting back off the paper.
                    You could confirm that by stopping the machine when it's printing just before or as the paper enters the fuser.
                    If the text is solid on the paper BEFORE fusing then that's where the problem is.
                    WARNING: Stopping the machine during printing could damage the fuser belt, probably won't, but it could.
                    Also is that paper going though the machine with that raised logo in the corner?
                    The text does looks a little more solid once it has passed the logo towards the trailing edge.
                    I'm wondering if that raised logo is making the fusing pressure / nip uneven.
                    It's hard to see (as could just be JPEG artifact background noise) but the grain of the paper looks pretty rough too, that could also effect fusing / bonding.
                    Have you tried printing on short edge feed?
                    Have you tried a different type / brand of paper?
                    • PA3040
                      • Jun 2014
                      • 171
                      Dear Cipher,
                      It is really really thanks for very logical and informative reply and please give me five hours to check the points that you pointed out
                      Yes. the above printout paper fully out via fusing
                      We very carefully observed that the logo( above image ) and some four color areas does not affected with this problem and we further observed that this issue heavenly effected for text and edges of the all of rectangle type images
                      Is it possible toner lifting back only for text area?( I think possible... please give me five Hours to confirm )
                      Thanks in advance.
                      • PA3040
                        • Jun 2014
                        • 171
                        Dear Cipher
                        Sorry for the late update
                        Please see the attached for just before enter the Fuser (Paper type 60 - 81 g/m2)
                        Please see the attached for just before enter the Fuser (Paper type 221 - 256 g/m2)
                        This is the image we can see on the ITB
                        Following image you could see unnecessary yellow pattern, which is we should not know what
                        Please advice
                        • Cipher
                          • May 2006
                          • 1309
                          Hmmm strange.
                          That yellow pattern is far to precise.
                          It looks a bit like a copy protection pattern or some kind of identification marker.
                          I'm starting to think this problem could be some kind of image processing fault.
                          If you have a PS3 option handy it might be worth trying that.
                          • SargeNZ
                            • May 2012
                            • 263
                            The yellow dots are the stenography patterns. Don't worry about them.
                            • PA3040
                              • Jun 2014
                              • 171
                              Dear Sarge,
                              Thanks for the valuable reply and It could be much appreciated if you can explain more about "stenography Pattens" which will help to update our knowledge and could you have idea about main issue?
                              Thanks in advance
