I have been working on a MP 5001 that continues to throw a SC350. Rebuilt the transfer belt because the pin was missing from the drive gear. New belt, blade, pin, and gear. Developer has 76,560 copies, drum, even fewer. Replaced ID sensor and had no issues for about a week and a half. I have been told that Ricoh recommends replacing developer when you install new ID sensor, but the developer here was not that worn. Should this be a concern? Thanks for any and all suggestions.
Ricoh MP 5001 SC350
Tags: None
Re: Ricoh MP 5001 SC350
From Goose's Guide:
D091/D092 SC 350 ID sensor error - check drum ground bearing D091/D092 SC 350 ID sensor error - check for drum damage in sensor path D091/D092 SC 350 ID sensor error - check for over or under toned condition D091/D092 SC 350 ID sensor error - check with SP3-103 for proper VSG & VSP readings D091/D092 SC 350 ID sensor error - clean and reinitialize sensor with SP3-001-002 D091/D092 SC 350 ID sensor error - replace HVPS
