Ricoh MP C4501 Admin Password
  • iam3rr0r
    Hello,
    Prior to posting this, I had searched through the Ricoh forum on here to find any info I could on a problem I'm having; however I'm not having much luck nailing it down. My apologies if this has already been covered elsewhere.
    We have several Ricoh MP C4000 (C4000 and C4501) series copiers where the admin & supervisor passwords have been set and long forgotten. To avoid the "red tape" and headache of replacing the NVRAM on all units, I've been trying to find a workaround to reset the passwords(or machine) to default.
    Ive tried entering SP Mode to clear all the memory--no luck (assuming because the passwords are on the NVRAM). Can't get in from the device itself nor the web console. I stumbled across this post and wondered if it may be what I'm looking for. seems like it. Before I attempt it, does anyone know if this will indeed work for my device(s)? If not, does anyone know of any other methods i should try?
    http://www.copytechnet.com/forums/ri...-password.html
    Perhaps I should just move the copiers under a leaky pipe and collect insurance?
    Before I resort to locating the plumbing schematics of my building, can anyone help me? Any help is appreciated!
    • 37641
    Re: Ricoh MP C4501 Admin Password
    There is a method in one of the threads for downloading the NVRAM contents to an SD card, then editing the contents to reset the password and upload the edited content back to the NVRAM. You will have to do it for each machine. If you choose to use this method, it would be a good idea on the first attempt to make a safety backup of the NVRAM contents. Actually, it is a good idea to make a safety backup of all NVRAMs. Then if you have a machine blow one, or as we had once, a pin on the NVRAM break off, you don't loose all settings.
    • iam3rr0r
      Thank you!
      • sandmanmac
        • 3990
        Originally posted by iam3rr0r
        Hello,
        If you performed a FULL memory clear, have you since thoroughly tested the machines - specifically full-colour scanning and copying?" That insurance claim might not be such a bad idea if you don't have the birth certificates for them.
        (Hopefully you only tried it on one of them).
          • 37641
          But they can get it back to proper color, if they have enough time spend on it, and maybe end up replacing the laser assembly in order to have the proper settings and the ID sensor for the same reason. It gets easier after 2 or 3 and you then have some idea as to where to start.
          • sandmanmac
            • 3990
            But they can getit back to proper color, if they have enoug time spend on it, and maybe end up replacing the laser assembly in order to have the proper settings and the ID sensor for the same reason. It gets easier after 2 or 3 and you then have some idea as to where to start.
            Agreed. There are ways to resolve the problems. I was just pointing out that a whole new set of issues had likely been needlessly created with the memory clear.
            • jazzih
              • May 2009
              • 10
              Reset admin and supervisor password
              Execute SP5846-046 in 143 not the 107 service mode.
              This will clear all address book and initial setting.
              remember to backup your address book before execute
              Cheers
              • Itanic
                • Dec 2014
                • 59
                Cheers
                I had exact sdame problem recently and tried what i thought was everything.. What jazzih is suggesting will work and is the easiest fix for you!
                • teebee1234
                  • Jul 2008
                  • 1670
                  Cheers
                  Why oh why did you feel the need to post this publicly. You should have sent it as a PM.
                  • zed255
                    How'd ya manage that?
                    • 1024
                    Agreed. Ricoh has already changed the main SP on the newer models because it became too widely known, which of course it was almost instantaneously posted anyway. If people keep posting this Ricoh may just change that too, or eliminate the back-door entirely. Then we are up the creek sans paddle...
                    People are responsible for their machines and the data they hold. If they set passwords and forget them then they should suffer the consequences of that. If a buyer doesn't know enough to check for passwords when selecting a machine, suffer the consequences.
                    • Black lung
                      • Sep 2010
                      • 15
                      Personally I'm happy this got posted. We have always used the NVRAM method, what a hassle. We buy ten to twenty lease return machines at a time and once in a while we are locked out of a machine.
                      I don't understand why this is a big secret, isn't this a tech help site?. We get parts support from a Ricoh dealer (we are not) and I have asked them about this in the past ... is there a backdoor like Kyocera has? The answer was always, not that we know of, I feel sand bagged.
                        • 37641
                        Most dealer techs who have never asked their regional support rep for help with lost admin and supervisor passwords do not know that it exists.
                        • 88hawkfan
                          • Jun 2014
                          • 76
                          We've been an RFG dealer since we started (20 years ago) and I've contacted numerous regional support reps and I've never heard of this, I too have always been told to use the NVRAM fix as there was no other work around. What a crock!!!!!
                          • jy123
                            • Jul 2018
                            • 2
                              • 37641
                              A few years ago Ricoh changed the sequence for entering main SP mode. One of the reasons for this was that too many unauthorized people had obtained them. WE ARE ONLY 1 FIRMWARE UPDATE AWAY FROM THEM CHANGING ACCESS TO FACTORY SP. When that happens we are all screwed.
