Staples end up on bottom of SR4030 finisher
  • Hadster
    • Aug 2011
    • 264
    This is on a Ricoh MP7001 and SR4030 finisher. Every other copy group is not getting stapled and the staples end up down at the bottom of the finisher. I had the customer try a different staple cart. with the same result. Anyone ever seen this before I go out there?
  • freginold
    • Sep 2010
    • 102
    Re: Staples end up on bottom of SR4030 finisher
    Sounds like the paper isn't getting stacked where it's supposed to be, so staples are missing. Check the reverse roller that hangs above the staple tray -- the gray foam roller. Make sure the little belt is there and on correctly. If that belt has popped off, the pages won't get stacked right.
    Config page instructions for copiers, printers, & fax machines
