MP C4501
  • CrapAimer
    • 296
    MP C4501
    Hi All have a weird one here, when the customer replaces the black toner it doesn't reset the toner level indicator, this is causing the machine to stop printing etc. I have replaced the toner pump as we thought it was the toner light that wasn't going out, also replaced the toner cartridge board, still wont reset it.
    Any thoughts appreciated
    Regards
    George
  • Moza
    • 232
    Re: MP C4501
    Regards
    George
    Check what SP 5051 TonerRefillDetectionDisplay is set to ? If its on you could try turning off and power cycle the machine then switch back on
      • 37491
      Re: MP C4501
      If this does not clear it, try SP 3045, Toner End Detection:Set. Same procedure change it, cycle power, change it back, cycle power again.
      • ss12
        • 289
        Re: MP C4501
        Regards
        George
        i Had the same issue recently on a mpc 5501 ,replaced black pcu, toner pump, rfid board still no joy.It ended up being compatable toner was the issue even though it had been replaced 3 times,as soon as the oem was fitted ,problem solved
        • mikadonovan
          • May 2008
          • 2931
          Re: MP C4501
          Check SP 3101-9. If it is a negative value, perform slimslobs procedure with a NEW cart installed. You may have to disable and enable 3045 a few times before it finally recognizes the cart.
          NEVER ASSUME ANYTHING
          • CrapAimer
            • 296
            Re: MP C4501
            Hi
            Slimslobs ???
            • mikadonovan
              • May 2008
              • 2931
              Re: MP C4501
              Hi
              Slimslobs ???
              3rd post on this thread.
                • 37491
                Re: MP C4501
                Hi
                Slimslobs ???
                Put an apostrophe between the b and the s. Possive of slimslob. Meaning my post.
                • CrapAimer
                  • 296
                  Re: MP C4501
                  Many thanks to all got it sorted by using the sp 3045
                  George
