Hello everyone. Looking to see if anyone has had an issue with a SC223 problem on a C4000. Problem popped up a little over a week ago. I went out and discovered the yellow LDB and other areas within the laser unit was contaminated with toner. I found the seals were in really bad shape so I cleaned up the inside of the laser unit, resealed it with a make shift seal in the badly affected areas, closed it up. It ran fine for a day or so but the next thing I know the SC 223 was back. This time I replaced the entire laser assembly and it was fine. That was on Wednesday. I just got another call for the same issue; same copier. I know the BICU is a candidate for the source of the problem but the issue goes away when I pull the laser, clean everything up and power it back up. Can anyone think of any areas I'm missing. This copier has been driving me crazy with one issue after the next.
Thanks all,
Jeff
Thanks all,
Jeff
