MP 7001 tandem tray locked / blocked
  • sabah_karim
    • Sep 2009
    • 67
    [Misc] MP 7001 tandem tray locked / blocked
    Hi
    MP 7001 tendam tray is locked / stuck up as it is not opening.
    even I use max. force. Just looking for solution.
    thanks
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: MP 7001 tandem tray locked / blocked
    If it's just the right hand side, open the left hand side and remove it. Place a large, sturdy screwdriver under the right hand side, lift it up and pull. It will come out. Someone has been a bit forceful closing the tray.
    Hit it.
      • 37490
      It has been maybe ten years since I have had this on a tandem tray. If I remember correctly we had to disconnect the finisher and remove the left lower cover. We could then at least look in and see what could be done. If I remember, it had to do with latch between the two halves and required a long screwdriver to disengage it. I think something to do with the latch release solenoid. After we figured it out, the next time was quick and easy. It was a Gestetner 3355, Aficio 550, in the yard office at a level 5 prison. Prison COs can be rather hard a machine.
      • Vollegaaz
        • 73
        yup, happens a lot when someone jammed the tray to hard in the machine, do as mentioned above!
