Ricoh SP5210sf SC545
  • roman2304
    • Oct 2013
    • 30
    Hi everyone.
    I have a RICOH SP-5210sf that was working just fine.
    A few days ago, it pop a SC-545 code.
    I cleaned the thermistor, check the fusing lamp and thermostat and everything work just fine after reseting the SC.
    Later, that same day, the SC-545 happend again.
    We change the fusing unit for a brand new but today the same SC pop again with the new fusing unit.
    Any sugestions on this SC??
    Thanks!!
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Ricoh SP5210sf SC545
    Goose's Guide:
    M052/M053/M054 SC 545 Heat roller lamp on full pwr - A level code, reset with SP5-810
    M052/M053/M054 SC 545 Heat roller lamp on full pwr - replace fuser assembly
    M052/M053/M054 SC 545 Heat roller lamp on full pwr - replace PSU
    • laitang
      • Nov 2012
      • 627
      SC545 Detail:
      Fusing lamp remains on
      Description:
      The fusing lamps remained ON at full capacity for more than 12 seconds after the fusing temperature attains reload temperature
      Possible cause:
      - Fusing thermistor defective
      - Defective fusing lamp
      - Thermostat actuation
      - PSU defective
      Procedures:
      - Replace the fusing thermistor.
      - Replace the fusing lamp.
      - Replace the thermostat.
      - Replace PSU
      • sandmanmac
        • 3983
        Thanks!!
        It looks like you've isolated the problem to the PSU
        • imihm
          • Feb 2014
          • 77
          Hi everyone.
          Thanks!!
          Hello there.
          If you are connecting the machine through power stabilizer please check stabilizer o/p otherwise check the line power.
