SD Card Authentication Fail in MP4000B
  • Wind Cool
    • May 2014
    • 82
    Hi !
    I encounter some problem of MP4000B.
    I was install a new SD Card printer scanner for MP4000B by adding feature to my customer.
    But it show " SD Card Authentication Fail "
    I had clear all memory and format HDD but still come with same problem.
    I had try the SD Card by others MP4000B copier and it show the SD Card no problem at all.
    May i know what is the problem ?
    Is it firmware issue or other issue?
    TQ!
  • sandmanmac
    • 3979
    Re: SD Card Authentication Fail in MP4000B
    SD CARD QUESTIONS SD Authentication Error when installing SD options - Update system fw 1.04 or later refer to tsb #11
    • Wind Cool
      • May 2014
      • 82
      Hi ! Yes, you are right ...
      Is firmware problem. I had update to 1.14 and it work.
      Thank you for your help and very much appreciate !.
