Ricoh MP6001 NVRAM
  • Hadster
    • Aug 2011
    • 264
    Ricoh MP6001 NVRAM
    I'm sure this has been covered a million times and the search bar for copytechnet sucks! Sorry, just a little frustrated because I cannot find what I need. I have a MP6001 that I would like to put a new NVRAM in first because the password has been changed (both admin and superviser) and two because I would like to zero out the counter. When I install a new one at the bottom of the screen the message is (Cannot install this software. This software has already been installed in another machine.) NVRAM is brand new. I would like to know the installation process to not have this message. I pray I have not already messed up the brand new NVRAM. Thanks!
    • 37372
    Re: Ricoh MP6001 NVRAM
    I hope that you either have the old NVRAM or that you backed it up to a SD card so the data can be restored to the new NVRAM. If that does not work, put the original NVRAM back in and somewhere on this forum there is a thread that has instructions as to how to edit the passwords sections of the backed up data. As for zeroing the counters, that is both illegal and unethical.
    • Hadster
      • Aug 2011
      • 264
      Yes, I know but I can't find the thread! As for it being illegal and unethical you would be wrong in this case. I sell them under the condition that the machine is totally refurbished with a life time replacement guarantee which the customer is WELL aware of making your point void!
      • mikadonovan
        • May 2008
        • 2931
        This may help.
        NEVER ASSUME ANYTHING
          • 37372
          Originally posted by mikadonovan
          This may help.
          Mika, I can't remember if you were the one who posted it originally, but that is the editing cheat sheet that I remember seeing before.
          • mikadonovan
            • May 2008
            • 2931
            I dont remember who posted it. I saved it to mess around when I get a chance.
            • NeoMatrix
              Senior Tech.
              • 3514
              It may have been skynetto who post it. I believe he has something similar with his password editor tool.
              I'm not absolutely certain the original text came from him though.
              • ruben
                The New Guy
                • Oct 2012
                • 1203
                Original thread: http://www.copytechnet.com/forums/ri...-password.html
                • Hadster
                  • Aug 2011
                  • 264
                  • Richariri
                    • Dec 2013
                    • 163
                    Our usual procedure for replacing an NV-ram in a reconditioned machine, would be to 'Download' the old Nv-ram data in SP5XXX to an SD card in the service slot.
                    We then replace the physical NV-ram and select Upload Nv-ram data.
                    Some issues I've come across after a successful download and upload is that the device settings (also in SP5XXX) don't enable NIC and USB, You will need to change their values to 1 to enable. Also, sometimes the Machine serial number disappears and it needs to be re-entered before you can do the upload.
                    The message you've recieved seems to me like you've got a Java or Security option card fitted from another machine. I've never had it when replacing an NV-Ram (yet).
