Ricoh Ap410n Jamming on exit
  • ASHLEY U
    • Oct 2014
    • 7
    [Jamming] Ricoh Ap410n Jamming on exit
    Hi guys,
    A bit of a relic but has anyone had problems with jamming on the exit on one of these? Paper comes 3 quarters of the way out then slows right down and intermittently jams. Any ideas?
    Cheers
  • wester
    • Aug 2009
    • 113
    Re: Ricoh Ap410n Jamming on exit
    Originally posted by ASHLEY U
    Hi guys,
    Cheers
    Not familiar with this model but I wouldn't rule out the fuser rollers slipping.
    • bob marley
      • Jan 2012
      • 1339
      Never work on this model but think exit roller and its pressure one can cause similar problem
      Live for yourself and you will live in vain. Live for others, and you will live again
      • Iowatech
        Not a service manager
        • 3930
        Huh, had to look that up on Google, but it looks like I may have worked on a couple of those back in the day. It's been a while, though.
        Still, for what it is worth, you might double check that the machine is set up to run that size of paper. Also check the fusing unit exit sensor to make sure it is operating correctly.
        Sorry if that was a waste of time.
