RICOH MP C3000 sc 442
  • tecnomarco
    • Jul 2011
    • 214
    Greetings all, I have a problem on this multifunction SC 442 can someone give me a hint on what to do? thanks
  • totoro
    • 568
    Re: RICOH MP C3000 sc 442
    SC442
    Dirty image transfer belt contact sensor
    Defective image transfer belt contact motor
    Disconnected connector of image transfer belt contact sensor or motor
    Disconnected cable
    1. Replace the image transfer belt contact sensor.
    2. Replace the image transfer belt contact motor.
    Totoro
    • tecnomarco
      • Jul 2011
      • 214
      thanks totoro, I change the transfer belt, and all drum unit, but this problem remain, it seems that the belt does not run
      • sandmanmac
        • 3981
        The contact motor/sensor are not part of the belt assy.
        • tecnomarco
          • Jul 2011
          • 214
          thank's sandmanmac, I disassembled the back and saw that the engine belt does not turn, can be a problem to which card?
          • tecnomarco
            • Jul 2011
            • 214
            anyone has any photos of this contact sensor / motor which is positioned
            • sandmanmac
              • 3981
              C3000 - ITB Contact motor.pdf
              You can check the motor with SP5-804-001
              • tecnomarco
                • Jul 2011
                • 214
                hi sandmanmac, I run the display 5-804-001 ON but the engine belt is not moving the copier have 180000 print
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  It's not the belt motor, it's the contact motor. It sits on it's own on the top right of the main drive unit.
                  Hit it.
                  • tecnomarco
                    • Jul 2011
                    • 214
                    hi tonermunkeh, you can tell me exactly where I'm going crazy, I have to remove the back?
                    • tecnomarco
                      • Jul 2011
                      • 214
                      hi tonermunkeh, is b223-1199?
                      • skynetto
                        • Sep 2012
                        • 257
                        Yes.
                        B2231199 DC Motor 24V
                        • tecnomarco
                          • Jul 2011
                          • 214
                          • skynetto
                            • Sep 2012
                            • 257
                            Buona serata anche a te.
                            • tecnomarco
                              • Jul 2011
                              • 214
                              Thanks also to all those who helped me in this problem and also to this site consists of very competent people
