ricoh mp161spf
  • anica
    • Dec 2014
    • 12
    ricoh mp161spf
    Hi, I got a ricoh mp161spf. It use to work on the network. I want to run it of a single computer. It does have a usb printer port.When inserting usb cable computer does not see printer/device. I will be glad if you can assist me how to print direct from the computer, with windows 7.
  • lukeh
    • Jun 2012
    • 43
    Re: ricoh mp161spf
    Check if usb is enabled in sp mode
    • anica
      • Dec 2014
      • 12
      Re: ricoh mp161spf
      How to get to sp mode?
        • 37533
        Re: ricoh mp161spf
        You obviously are not a Ricoh technician as it is the same as for most other Ricoh MFPs. That said, the following key sequence:
        Clear Mode Key (Usually yellow)
        1
        0
        7
        Hold the "Stop/Clear" key (Usually Orange or Red) for 3 to 6 seconds.
        Copier Service Program SP 5985-002 set to 1. If it is already set to 1 then the USB port is bad and the board will need to be replaced.
        The other option is to get a network switch or use a cross over cable.
        • anica
          • Dec 2014
          • 12
          Re: ricoh mp161spf
          1
          0
          7
          HI, I press Clear key, then 1 0 [like 10 copies] and I cannot type 7. Am I doing something wrong here?
          • ruben
            The New Guy
            • Oct 2012
            • 1203
            Re: ricoh mp161spf
            Doesn't matter, do EXACTLY the above this will get you into SP mode.
            • Iowatech
              Not a service manager
              • 3930
              Re: ricoh mp161spf
              This might be stupid, but I'm still curious. Anybody else here think it might be a good idea to check whether this person has downloaded the latest drivers from Ricoh before we send them mucking about in service mode?
              Sorry, I'll just shut up and go away now.
                • 37533
                Re: ricoh mp161spf
                Do not worry about what is on the display. Just press the key in the correct order. If you take too long to press them all, you will have to start over.
                • anica
                  • Dec 2014
                  • 12
                  Re: ricoh mp161spf
                  thank you, I got in there in the maze.
                  It seems like the version is [1.05]
                  I select 3 for printer, It says printer class 1. service mode. I select ok and it says 1;001 bit switch. When I press ok, it goes to 001.001 bit switch 1--7 with some 00000 bits underneath.
                  I found this in the manual. 2) Select SP5-985-001 (NIC setting) and change the setting value to "1" (ON).
                  3) Select SP5-985-002 (USB setting) and change the setting value to "1" (ON).
                  Can you direct me inside the service mode.
                    • 37533
                    Re: ricoh mp161spf
                    I originally stated Copier not printer. Depending on model and firmware level it may show as System SP.
                    • anica
                      • Dec 2014
                      • 12
                      Re: ricoh mp161spf
                      Yes you can choose fax, scan,copy or print sp.
                      • orohu_Emmanuel
                        Re: ricoh mp161spf
                        Hi every body I have a Ricoh copier Mp5000 after changing the maintenance kits we used it for just a day the copy quality was OK, and after some time it started bringing poor copy as if the cleaning blade is bad but we just changed every things. Can any body help please.
                        • orohu_Emmanuel
                          Re: ricoh mp161spf
                          [QUOTE=orohu_Emmanuel;450182]Hi every body I have a Ricoh copier Mp5000 after changing the maintenance kits we used it for just a day the copy quality was OK, and after some time it started bringing poor copy as if the cleaning blade is bad but we just changed every things. Can any body help please.
                            • 37533
                            Re: ricoh mp161spf
                            This has nothing to do with this thread. Start a new thread if you want us to help you.
                            • anica
                              • Dec 2014
                              • 12
                              Re: ricoh mp161spf
                              Thank you guys, I manage to come right with you advice.
                              When I print, the print alarm comes up, paper mismatch. everything is set to A4. I have to select form feed on the panel and then it does print. Do you know why it does that.
