c231sf
  • LNorris
    • Sep 2008
    • 645
    c231sf
    had another tech install a paper end detection into tray 1. now the machine will not pull from tray 2. the print driver and the machine knows its there, however, if you pull out tray one, you can feel the feed roller turn and give jam indication. put tray one back in and it feeds fine from one. not sure what he did or whats causing 1 to try to override 2. i have set the default to 2 as well and still same issue.
    any ideas?
