Ricoh 2045e--sc322
  • clemsonfish
    • Oct 2014
    • 27
    [Error Code] Ricoh 2045e--sc322
    went to machine for service call dumping toner, pulled pcu, developer unit, toner hopper cleaned and cleaned inside of the machine. put back together. tried to make a copy. paper got to the registration roller, stopped and gave an sc322. laser sync error. took laser unit out and completely cleaned it. put laser unit back in and ran sp2109-8, sp2109-3, and sp2109-4. still doing the same thing. paper gets to the registration roller and stops and gives an sc322. checked all connections, and cables and all seem to be just fine. this is an old machine and we are trying to get them to replace and dont want to put in a LD unit ($$$) if i can help it. any suggestions?
  • nmfaxman
    • 1702
    Re: Ricoh 2045e--sc322
    Take the laser apart and clean the mirrors. Very common on these pigs.
      • 37532
      Before replacing the Laser Diode assembly first try replacing the sync detect board. Check the connection from the sync detect board and LD unit.
      • clemsonfish
        • Oct 2014
        • 27
        Thanks for the response but i completly took it apart and cleaned everything still the same thing
        • clemsonfish
          • Oct 2014
          • 27
          I will try this next thanks slimslob
          • TonerMunkeh
            Professional Moron
            • 3865
            Change the door switches first, if the machine was really dirty they will have become contaminated.
            Hit it.
            • bob marley
              • Jan 2012
              • 1339
              It seems that the whole problem is the LD. Try clean it and check sp 2103 (LD Power Adjustment ) , also as TonerMunkeh mentioned u can change switches , specifically which are on the right side , one of them if it is dirty or defective can cause LD problem
              Live for yourself and you will live in vain. Live for others, and you will live again
              • Herostrat
                • Oct 2012
                • 220
                Try it with cheated switches of the side doors,does it pop the code right after the ID pattern is created on drum?
                I'd guess that ID sensor isn't in place,meybe u forgot to clean it or drum skraper is in bad condition and lets the waste toner out on ID sensor.
                Dusting on them can be caused by bad drum entrance seal,developer unit filter,developer unit entrance seal,Bad drum scraper,if any of those are in bad condition toner dusts on laser unit.
                Look for yellow cable connector on Laser unit,if he is not in place properly he can give you SC322,Clean all mirrors as stated before.
                I'd wait with changing boards cause it can't malfunction just like that,it worked fine before you got there
                Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
                • flo
                  Engineer
                  • Mar 2009
                  • 44
                  I have this prob often by this modell. first thinking is LD Unit but it was always the Doorswith on left Side from Fusing and Separation Unit. There are 4 of them as a Part. Propably change it all. They open 12V und 24 V Current and sometimes its give nearly 18 - 19 V thats enough to recall a SC Code for LD Unit like a defective Polygon Mirror Motor. It's possible you can clean the Switches but its may a difficult work.
                  • kannuki2
                    • Feb 2012
                    • 398
                    yes agreed with Flo. Replaced those 3 interlock switches on the right side when facing the front cover door. There is a way you can bypass it from the LD board but i forget the positioning pins.
                      • 37532
                      It is either a 2 pin connector or a three pin connector with only 2 leads. I used to use a staple to bypass it for testing.
                      • clemsonfish
                        • Oct 2014
                        • 27
                        When i first got to this machine it was bad there was close to an 1/8" of toner under the bottom of the dev unit. Aparently the old tech we had told them "there was nothing he could do for it and when it started making bad copies to pull the shield glass and clean it". I've ordered new entrance seals , The old ones were horible, im gonna replace those when they open back up from the hollidays.
                        Was wondering if anyone had the part numbers for the door switches?!?
                          • 37532
                          Two 12042521 Micro Switch and one 12042529 Switch - V -5F912DN. Also check that the additional seals have been installed per TSB 030.
                          rfg016662-030.pdf
                          • allan
                            RTFM!!
                            • 5462
                            Very sensitive to static. dont bring vacuum or blower close to the ph unit. swoped plenty of those not like 3025 that you can clean.
                            Whatever
