mp9000 jam
  • vargue
    • Oct 2011
    • 404
    [Jamming] mp9000 jam
    hi fellas recently worked on mp9000 and when machine start it's revealed (R) JAM in finisher then i must open finisher and close it .and no papers found. every time in opening machine. i noticed that finisher tray . not move down .it's move left right .when sorting .i makes test on left motor while machine start .it's raised but when sorting not get down. help please
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: mp9000 jam
    Which finisher does it have and what jam code is logged????????????????????????????????????????
    Mystic Crystal Revelations
    • Jan
      • Dec 2014
      • 15
      Re: mp9000 jam
      if it's an sr5000, replace the motor that moves the tray up en down, it's a common problem.
      Kind regards
      • vargue
        • Oct 2011
        • 404
        Re: mp9000 jam
        b830 j116 jam code
        • vargue
          • Oct 2011
          • 404
          Re: mp9000 jam
          i get down tray manually with my hands until down and switch off and on it's raise up if it's tray motor yo will hear big noise .
            • 37641
            Re: mp9000 jam
            b830 j116 jam code
            Per Goose's Guide Jam Code 116 is the staple motor defective, or could be a loose connection or defective going to the stapler. If you have another finisher around, try swapping out the staple head. Now if you had put the jam code in your first it would have saved a couple of days getting to here.
            • Ollie1981
              Toner Monkey
              • Mar 2008
              • 417
              Re: mp9000 jam
              There should be a black, L-shaped stack height arm that rests on the shift output tray.
              If that is out of it's bracket or missing completely the tray will drive all the way down until the motor loudly clicks and will usually indicate a jam 1-2 times, then an SC750 (I think, but I'm not getting the manual out) code.
              Also, in the runners of the shift tray there should be upper and lower limit sensors, check they are present and correct.
