error sc 705 ricoh 2105
  • feroo666
    • Dec 2014
    • 23
    i have ricoh 2105 it gives me error sc 705 can any one help me
  • allan
    RTFM!!
    • 5463
    Re: error sc 705 ricoh 2105
    Are those things still running? I hatted those machines! used to clean out toner pipes everyday.
    Whatever
    • feroo666
      • Dec 2014
      • 23
      It make me crazy
      • bob marley
        • Jan 2012
        • 1339
        SC705 is ADF Original Table Lift Malfunction
        Definition [B]
        One of the following conditions was detected.
        The bottom plate position sensor does not activate when the bottom plate
        motor lifts the original table.
        The bottom plate HP sensor does not activate when the bottom plate motor
        lowers the original table.
        Possible Causes
        Bottom plate position sensor defective
        Bottom plate HP sensor defective
        Bottom plate motor defective
        ADF main control board defective
        Live for yourself and you will live in vain. Live for others, and you will live again
        • feroo666
          • Dec 2014
          • 23
          Definition [B]
          Possible Causes
          please can you explain how can i solve thise problem
          • allan
            RTFM!!
            • 5463
            Inspect the document feeder for problems. The paper lift for your originals is faulty.
            Whatever
            • feroo666
              • Dec 2014
              • 23
              will try thanks my brother
              • feroo666
                • Dec 2014
                • 23
                thanks it's solved
                • allan
                  RTFM!!
                  • 5463
                  What was wrong?
                  Whatever
                  • JuanjoSVQ
                    • 1
                    Maybe the lift harness
                    Enviado desde mi iPhone utilizando Tapatalk
                    • bob marley
                      • Jan 2012
                      • 1339
                      sorry 4 the delay in replay . Because of an unexpected obstacles I were away
                      glad u could solve it
                      • feroo666
                        • Dec 2014
                        • 23
                        What was wrong?
                        gears Unit in ADF was not moving I disassembled and cleaned and add them again
