Computer when i send job can see it being sent to copier clears job but nothing comes out. On copier i don't see data light come on. The Print drivers loads and installs with no problem. I can scan to folder / copy/ doc server / fax that all works. Almost acts like user code is enable but not have check. When i go try the web monitor says forbidden .
