SR 3020 Mylar
  • mikadonovan
    • May 2008
    • 2931
    SR 3020 Mylar
    Can anyone tell me the part number of this little mylar? This is a B804 3020 finisher. I have had a rash of these becoming damaged and in need of replacement. I really don't want to order and replace the entire belt assembly just to get a .50 cent mylar.
    NEVER ASSUME ANYTHING
    • 37532
    Re: SR 3020 Mylar
    Mika, it is not sold separately. You need to order the entire exit belt assembly, item 16 on the drawing. You have to disassemble the entire staple table to replace it.
    • RG1964
      • Jul 2009
      • 56
      Re: SR 3020 Mylar
      Can't you replace the mylar with a "homemade" one? In the worst case i would order the exitbelt, undo the bold/nut (exitpawl) and screw it on to the old belt, It's a lot of work to replace the entyre exitbelt. By the way, is it an essential mylar? It wasn't on the previous models.
      • mikadonovan
        • May 2008
        • 2931
        Re: SR 3020 Mylar
        I guess I'll have to manufacture it. The trick is finding a quick drying adhesive to attach it. Superglue doesn't cut it. They are necessary. When damaged or deformed, the paper entering the staple tray will get stuck under the metal belt hook instead of sliding back down into the paper holders causing the sheet to be stapled somewhere other than in the middle when making booklets.
        • Zaxxon
          • 608
          Re: SR 3020 Mylar
          How about buying the entire unit and unscrew the needed part of and attache it on the old belt?
          Please start you post with brand, model, problem.
          • mikadonovan
            • May 2008
            • 2931
            Re: SR 3020 Mylar
            You must have missed this part.
            • RG1964
              • Jul 2009
              • 56
              Re: SR 3020 Mylar
              You can use the glue for model airplanekits, it's in a tube (thick) but there is also a liquid one with a brush to apply the glue.
              Good luck
              • Zaxxon
                • 608
                Re: SR 3020 Mylar
                My mistake, sorry. Really thought the hard job replaceing the entire belt was the real issue.
                • LNorris
                  • Sep 2008
                  • 645
                  Re: SR 3020 Mylar
                  Mika
                  thought you were trying to replace the whole thing. i've had paper get stuck under that as well, i put some electrical tape on the bottom side and then bent it around the belt...kinda like a 90 angle. worked fine.
