Ricoh C6000 error code SC-413?
  • Bocfus
    • Dec 2014
    • 16
    [Error Code] Ricoh C6000 error code SC-413?
    First time on. I have a Ricoh C6000, runs for awhile then it will stop and I have to re-start from screen. I look in SC history I'm getting an SC-413, I know it has something to do with the yellow ID sensor. Has anyone seen this and what did you do. Thanks.
  • Timmytronic
    • Oct 2010
    • 249
    Re: Ricoh C6000 error code SC-413?
    Hi
    Have you cleaned the sensor, I tend to take it out and blow it as dust can cause silly errors.
    Tim
    • TonerMunkeh
      Professional Moron
      • 3865
      Agreed. Strip and vac all units including ITB. Check PM life on ALL parts and replace if required. Don't skimp on the service time or parts on these things, they work a hell of a lot better if they are maintained correctly.
      Hit it.
        • 37560
        Change SP5875-001 to 1 and the C6000 will display the SC code instead of the reboot option.
