resetting a Aficio MP 4002 to factory settings
  • landspeeder
    • Feb 2010
    • 355
    Happy New Year to All!!!
    Got a MP 4002 in off lease...how do you reset to factory so I can get rid of all the address's etc. I got the service manual but I cant find it....
    Many thanks eh!
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
  • imaginemoko
    unTrusted Tech
    • Jan 2008
    • 289
    Re: resetting a Aficio MP 4002 to factory settings
    Initialize the NVRAM (SP5801-001) and HDD unit (SP5832-001)
    fix the customer first then fix the machine... its simple and makes life more easy.
    • Moza
      • 232
      Woooooh there !! Do NOT run SP 5801 unless you want a whole heap of trouble. This will reset all engine SP settings back to before factory adjustments and probably screw up your dev at least.
      You could format HDD but better off running SP 5846-047 this will just wipe the address book
      • landspeeder
        • Feb 2010
        • 355
        Thanks....how do you get into the sp mode? I see in the service man. about turning the service mode lock off and where to find it...I cant find it where its supposed to be....
        • Moza
          • 232
          Yellow c button then press numbers 1 0 7 and hold down grey c button
          • techsass
            • Dec 2010
            • 248
            Hold down the "COPY" key while you turn on the machine. I saw that on this site somewhere and it's stuck with me. I've yet to try it, but it's supposed to put all of the settings back to factory Default.
              • 37533
              Only works for certain printer models!
              • bob marley
                • Jan 2012
                • 1339
                that is right slimsslob
                Live for yourself and you will live in vain. Live for others, and you will live again
                • Richariri
                  • Dec 2013
                  • 163
                  On top of wiping the address book in SP mode (5846-047)
                  Go into system settings > administrator tools > Page 2 and select 'delete all data in document server'.
                  Then go back to user tools, hold the # key and select system settings. It'll then ask if you want to reset to factory default settings. Do this and all your data should be removed (repeat for fax, scanner, printer etc.)
                  If you have a fax installed, the transmission log will need to be formatted in Service Mode.
                  This is what I do before testing or refurbing any copier.
                  Hope this helps,
                  Peace
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    WTF dude?
                    Seriously?
                    In Factory mode just clear UCS and User settings SP...job done and you haven't had to do a clear all.
