Ricoh MP 7001 SC 745
  • copytrust
    • Feb 2010
    • 115
    Hello guys i have a Ricoh mp 7001 when you turn on the machine shows a jam on the sorter (it is a SR 841),
    then you open the door sorter and closed the jam goes away, and then the SC841 shows up!!!
    Anyone has any ideas???
  • ponto700
    • 144
    Re: Ricoh MP 7001 SC 745
    If you disconect sorter from machine and power it on gives you any code?
    • copytrust
      • Feb 2010
      • 115
      No it doesnt. The machine shows the SC 745 you press the exit button and works fine, but when you press staple shows again the error!!!
      • TonerMunkeh
        Professional Moron
        • 3865
        Is an SR841 not too old to be paired to a 7001? Has it always been connected to this machine?
        Hit it.
        • copytrust
          • Feb 2010
          • 115
          I am not sure about that, but i have to say that the machine was working fine with this sorter until now.......
          • fshead
            • 2356
            am i m reading this right
            are you getting sc 745 or sc 841???
            ve had some staple units give me wierd stuff over the years,swapped them out but
            if it sc 745 it should be something you can check by swapping out and confirming everything is where it should be..
            Feed-Out Belt Motor Error (D373/B830)
            745 D The stack feed-out belt HP sensor does not activate within the specified time
            after the stack feed-out belt motor turns on. The 1st detection failure causes
            a jam error, and the 2nd failure causes this SC code.
              • 36796
              Anytime you get a jam message on the finisher followed by an SC after you open and close the door, the SC is the actual problem.
              • copytrust
                • Feb 2010
                • 115
                And yes it was the stack feed-out belt HP sensor it was broken, because the sorter was a booklet there was no optical access i had to remove a lot to see it!!!!
                Thank you all guys!!!!
