MPC3500 Fax question
  • neergish
    • 177
    Is there any way to configure a MPC3500 MFD to fax an A4 long edge first page in immediate transmit mode without it shrinking to A5 at the other end?
    I thought this was a restriction of using immediate transmission because it was scanning and sending at the same time, but a customer insists it is posible. Thanks for any help.
    "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    imediate trans dosen't put the image into memory prior to sending so there is no page rotation before transmission. If the receiver machine has the capability it could do this on reception.
    Mystic Crystal Revelations
