sr5020 jam j411
  • slot
    • 341
    sr5020 jam j411
    looking at a sr5020 0m an 907 that bkeeps coming in with a jam of 411 fold unit entrance sesor all seems ok in that area and i have checked the pressure rollers are in the correct place with the disk in the squre hole so the rollers are out of the way when the paper enters this area has anyone had this problem many thanks for any input
  • Iowatech
    Not a service manager
    • 3930
    Re: sr5020 jam j411
    Booklet folders have a unit that pushes the center of the paper stack to the pressure rollers. That would be something I would check if I had an entrance jam, so you might want to check that too.
      • 37502
      Re: sr5020 jam j411
      From Goose's Guide: booklet stapler Late (D434) update engine fw to 1.12:04 or higher
