Ricoh 3025 fuser coupling gear replacement
  • copyaction
    • Oct 2007
    • 985
    Seriously, is there a way to replace the fuser coupling gear without taking apart 90% of the back of the machine?
  • mikadonovan
    • May 2008
    • 2931
    Re: Ricoh 3025 fuser coupling gear replacement
    Yep. Install a different machine with a undamaged gear I feel your pain, I had to deal with a fuser drive gearbox on a 1022 a couple of weeks ago. Disassembly sucked, reassembly was damn near impossible. Bring your lunch and make sure you have several beers in the fridge at home for afterward when you reevaluate your chosen profession.
    NEVER ASSUME ANYTHING
    • copyaction
      • Oct 2007
      • 985
      That's what I was afraid of
