ricoh mp5002sp
  • kopirmaster
    • Apr 2011
    • 70
    [Error Code] ricoh mp5002sp
    ricoh mp 5002sp .sc 819 after switching off.everyting is works very good but when you turn of the machine error 819 comes .i update the firmware and stil have the code .any help pls
  • freginold
    • Sep 2010
    • 102
    Re: ricoh mp5002sp
    It's probably the hard drive. To confirm, turn the machine off, unplug the hard drive, and turn the machine on. You'll probably get an address book error because the HDD is disconnected, but if the sc819 doesn't come back, it's the hard drive. You can try reformatting it once you plug it back in, but if that doesn't work, replace the hard drive.
    Config page instructions for copiers, printers, & fax machines
    • Moza
      • 232
      Re: ricoh mp5002sp
      Im afraid SC819 is more likely to be the controller
        • 37490
        Re: ricoh mp5002sp
        Fatal Kernel error: Turn off SSID Log into WIM as admin, configuration SSDP inactive
        Fatal kernel error: replace controller
        Fatal kernel error: update system fw to 2.00.3 or higher
        • kopirmaster
          • Apr 2011
          • 70
          Re: ricoh mp5002sp
          firmware is up to date .
          hdd format dont fix the error
          ssdp inactive ,dont make changes the error is stil here
          any ideas ????
          • mikadonovan
            • May 2008
            • 2931
            Re: ricoh mp5002sp
            Seems to be the next step....
            NEVER ASSUME ANYTHING
