Ricoh MP C2500 paper jams
  • jonbonse
    • Jun 2009
    • 730
  • steele
    • May 2012
    • 48
    Re: Ricoh MP C2500 paper jams
    Did you change torque limiter with roller?
    • Richariri
      • Dec 2013
      • 163
      Yes, those feed tyres are basically the same.
      Like steele said, you'll probably need to change the torque limiter.
      Could also be the feed guide which has two little plastic bits that apply pressure, I've had several where one side breaks off and causes intermittent jams.
      Also, remove the feed ass'y and play with the mechanism, when they get older the feed tyres don't return all the way back to position and can cause misfeeds. (i've only had success fixing one, most of the time it's unrepairable)
      Finally, and I don't think this is your issue, the feeler that's part of the feed unit can break it's axle when someone pulls the tray out and immediately slams it back in. This normally causes 'no paper' but if it's still in position and falling out with the vibration of the machine, it could stop the process and cause a jam.
      Hope something in this helps you...
      ...good luck.
        • 36869
        If you have not replace the rollers, you might want to do so. The one way bearing in the feed roller can go bad and when the shaft turns, the roller does not. The pick up roller drives off the feed roller.
        • izzynut
          Gov.
          • Aug 2013
          • 5347
          Yes I've seen a brand new feed roller that the one way bearing was bad and cause myself some problems when I replaced it.
          • ruben
            The New Guy
            • Oct 2012
            • 1203
            You can use AF03-0090, 1090 and 2090 in most of the MFP range upto the new 03s (except pickup in 01s and 03s, which are different). Also, some of the feed assemblys are the same or very similar.
            • ruben
              The New Guy
              • Oct 2012
              • 1203
              Correction, maybe 01s to 03s. Parts look similar but might not work, so far they have for me.
              • jonbonse
                • Jun 2009
                • 730
                Thanks but would the the whole feed assembly from a MP C2800 fit a C2500?
                • Gift
                  • Mar 2011
                  • 2444
                  Probably just the feed clutch if the rollers are fine. Can't recall having this on a MPC2500 but sometimes the white holder (you need to remove when swapping the feed(pickup roller) can block the mechanism. You can remove it and just use clips like the previous models.
                  • Richariri
                    • Dec 2013
                    • 163
                    just realised I had a similar fault not long back and it was due to the white T shape holder that holds the pickup and feed tyres in place.
                    When I took it off, there's a rim moulded to the white T and it had uneven wear. It was causing the rollers every now and then to slip and cause an intermittent jam (usually only when doing a large print job)
                    • acharrison
                      Dear sir,
                      Would have the spare parts of the Ricoh MP C2500, I have to change the rollers on it too.
                      Is there a way to turn off the J001 signal or alarm has been set to 0 in JAM Alarm.
                      I live in Switzerland, so looking for a cheap UK / US supplier.
                      Thanks, AH
                      update; 10/7/2020 15:00 pm All parts
                      Ricoh Aficio MP C2500 Parts List and Diagrams Manual
                      CZ??CI DO KOPIAREK RICOH, GESTETNER, REX ROTARY, NASHUATEC, KONICA, MINOLTA, B?BEN, MITA, LANIER, TONERY, DEWELOPERY, TONER, LISTWA CZYSZCZ?CA, WARSZAWA Czechia Supplier, cheap.
                        • 36869
                        Originally posted by acharrison
                        Dear sir,
                        Thanks, AH
                        This thread is over 5 years old, dead and was buried. If you need assistance start a new thread grave digger.
