MPC2500 - Bizzare Printing Issue
  • PaulLoveless
    • Jun 2008
    • 26
    Here is a doozie-
    Brand new MPC2500. Updated Print/System/and NIC/ firmware.
    Problem:
    Lines that go left to right, margin to margin, about 2cm apart from each other from top to bottom.
    The lines are process black lines and you can tell the registration is a touch off.
    Conditions-
    This happens every print, regardless of test page or document.
    Notes-
    Of course, does not happen during copies or even Internal prints.
    Trouble shooting steps-
    Printer SP - Did a color test print. (Where the Data light lights up and then prints a color test sheet) Worked fine, no lines.
    Tried PCL6, PCL5c, PS, & PPD driver, no change. Lines still exist.
    Hooked up via Cross over, tried all different drivers, no change. Lines still exist.
    Whats insane to me is that if you do a print test page under printer SP, the data light lights up. But the print is fine.
    I will post up an example in a little bit when I get a hold of it.
    Ricoh Tier 1 is also clueless.
    Thanks for your help as always.
  • PaulLoveless
    • Jun 2008
    • 26
    Example
    • FRIDGEMAGNET
      • Aug 2007
      • 377
      Looks to me like a problem with the memory DIMM
      • PaulLoveless
        • Jun 2008
        • 26
        Of course, the one thing I did not order...lol
        • Ricoh-ono
          • 339
          I agree. It probably is the memory. I had this happen occasionally on the Aficio 1045's and 2232's.
          Do what you can, with what you have, where you are. ~Theodore Roosevelt
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            Take the dimm's out and clean the contacts with alcohol and clean the socket.
            Mystic Crystal Revelations
            • PaulLoveless
              • Jun 2008
              • 26
              Thanks guys I will try this and advise.
              • pspahr
                Toner Schlep
                • May 2008
                • 227
                One more Question
                Does this MPC2500 have the Fiery E 3000 installed? I've seen that a couple of times on multiple brands with a fiery attached. It was the video board, which is used on multiple Fiery servers.
                VectorLinux---Check it out!
                • PaulLoveless
                  • Jun 2008
                  • 26
                  No Fiery here.
                  Thanks though!
                  • swmckenna
                    Definitely sounds like memory.
                    • PaulLoveless
                      • Jun 2008
                      • 26
                      Wanted to update you all:
                      It was infact the memory. I reseated the DIMMS and we were golden.
                      Thanks so much for everyones input!
                      • Tonerbomb
                        • Feb 2005
                        • 2589
                        Nice!! Thanks for the update!!!!!!!!!!!!!
                        • WassaG
                          MPC2500 lines
                          Try going into SC5801 and clearing the printer memory only had a similar prob and this fixed it
                          RGS WassaG
