MP 161 L scan with USB port
  • tonnerboy
    • May 2011
    • 212
    Hello.
    I have one costumer that have an MP 161 L on his personal PC with Win7. He need to scan with it. Is it possible?
    This device is plugged into a USB port. I installed a DDST printer driver to make it print, and I think I need to install a DDST twain drive. Is it true?
    I tried to install it in my PC but with no success... gives me an error when I try to setup...
    Is there anything else I can do to make it work?
    Thanks for your replies.
  • sandmanmac
    • 3985
    Re: MP 161 L scan with USB port
    Scanning is only possible via the (optional) network port - not USB
      • 37560
      Depending on the exact model of MP 161, it may not have scanning. I do not recognize the 161L so it might be a non-US model. The MP 161SPF is the US model that comes with scanner. The other models need to have it added as an option.
      • ruben
        The New Guy
        • Oct 2012
        • 1204
        This model can do GDI scanning, but it is very flakey, and requires the correct application and possibly OS. This model cannot be upgraded to SMB scanning.
        The L has copier, printer, scanner and USB by default. The LN has all that with NIC. They are different to the F and SPF version as they don't come with a fax option, also they have a TINY (48MB and 80MB, respectively) amount of memory to process scan jobs with.
        To get this model to scan you will need to install a third part TWAIN application, Windows 7 does not come with TWAIN scanning capabilities, instead it uses WIA.
        • tonnerboy
          • May 2011
          • 212
          Thanks so much for your info... Do you suggest or do you know any third part TWAIN application for Win 7?
          What about the DDST TWAIN driver? It might do the job?
