MPC2050 locks up when printing certain document
  • copyaction
    • Oct 2007
    • 985
    Customer trying to print a contract and the copier stops printing from all computers.
    They have to go in to the print que and delete the job, will not cancel from the printer screen of the copier.
    Only happens with this one type of file everything else prints fine.
    Any workaround for it?
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: MPC2050 locks up when printing certain document
    Well what is the file type??????????????
    Mystic Crystal Revelations
    • copyaction
      • Oct 2007
      • 985
      sorry she just said it is an "odd pdf" I will check when I go in the morning.
      I was able to get her to clear it over the phone but she called back when someone else tried to print it again.
        • 37319
        Install Special/Custom firmware PCL V1.05.1 LR0008 date 7/22/2014. This corrects a PCL firmware bug. The character-rendering position is incorrectly calculated during the font-hinting process, which causes memory corruption and results in the SC899 error. SC899 occurs when printing from some websites using Internet Explorer.
        • Zaxxon
          • 608
          Perhaps a silly question, but are these special firmware available from any official Ricoh download site?
          Please start you post with brand, model, problem.
            • 37319
            In the US they are available from both Ricoh's TSRC and rfg-esource.
            • copyaction
              • Oct 2007
              • 985
              Ok so the document is a pdf scanned from a desktop "Neat" scanner, it is 28 pages and around 13MB mostly b & w but scanned in color.
              They had a similar 18 page document from the same scanner around 11MB that printed complete but did take about 5 minutes.
              • sandmanmac
                • 3979
                I have more questions than solutions:
                I'm leaning towards an issue with the file conversion software on the scanner.
                Can they print the document to any other printer in the office? Can you take a copy of the document to try to print elsewhere and/or connect directly to the Ricoh with a laptop and try.
                ALSO...why don't they simply scan this document with he Ricoh?
                • nmfaxman
                  • 1702
                  Select "Print as image" in the document print preferences.
                  Make sure print queue is set for LPR and the queue is lp.
                  Not a copier problem. It is an application problem.
                  • copyaction
                    • Oct 2007
                    • 985
                    now THAT is a great question. it is a large office and she doesn't want to walk all the way to the Ricoh so she wants to scan right from her desk.
                    I told her just to use the Ricoh in the future to scan these.
                    I know there is no problem with the copier but you know how it is hard to convince the customer of that sometimes.
                    As always, thanks for the responses.
