Fax nt recognized
  • kpad
    • Aug 2014
    • 3
    [Misc] Fax nt recognized
    New out of box MPC6502 not recognizing fax. Any ideas?
  • mikadonovan
    • May 2008
    • 2931
    Re: Fax nt recognized
    Make sure the MBU is seated well on the FCU and switch the battery jumper to the "on" pins.
    NEVER ASSUME ANYTHING
    • LNorris
      • Sep 2008
      • 645
      if you installed the fax, check the jumper on the fax. make sure its on.
      if you didnt install, is it showing under SP modes? or user tools?
      • kpad
        • Aug 2014
        • 3
        All that has been done. Not showing in UT or SP mode. Ordered new fax option.
        • Bantams
          • Jun 2012
          • 603
          Wrong fax option perhaps?
          Its not the same as the MPC6501 that's why I ask.
          • rsyarcia
            Hair Straightener Tech
            • 711
            Encountered with different machine(MP C4503)it can't detect the Fax option . Just updated the firmware and it worked fine. Maybe firmware issue.
            Nobody is perfect..
            • kpad
              • Aug 2014
              • 3
              Firmware fixed this, not sure why, but it did, Thanks
