ricoh 1013 wrecks p.u's
  • geewad
    Hi guys ,sounds a bit sexist sorry,
    I'm a newbie and theres always reasons for joining forums...help!!!
    I have about 6x ricoh1013s out in field that wreck new p.u's after approx 3/4k copies.2 or 3 are low mileage.background on both sides with couple of cross lines on rear of page leads to jams at ht at times.New p.u and quality is excellent again...all contacts clean and ok.Any suggestions much appreciated
  • PaulLoveless
    • Jun 2008
    • 26
    Tell your customers to use the CORRECT Ricoh genuine toner.
    • geewad
      Paul,thanks for reply and I will look into it.cheers mate.
      • PaulLoveless
        • Jun 2008
        • 26
        NP. Thats the only thing I can think of.
        Are the 6 different units having the same problem at the same site or are they in separate places and unrelated?
        • Fearless V K
          • 620
          When the p.u.'s fail, are they pulling developer? I have seen some of these with problems related to transfer roller cleaning current. They will start to pull developer, and cause background on the rear side of the copy when the roller becomes contaminated with toner. Try messing with the transfer cleaning current, increase or decrease it and see if it makes a difference. I usually end up reducing it to the minimum current value, but not always. Hope this points you in the right direction.
          Don't take that toner with me!
          • geewad
            Thanks fearless v k I will look into it today
            I checked dev in one and it was grey,I will check roller and most codes for charge are at default.Thanks for reply.best regards
            geewad
