spc 221 222 models small junk model copy quality issue
  • Counsel
    • Aug 2011
    • 529
    Hi all,
    Not sure if anyone deals with these much, they are the desktop type machines with crappy pcu cartridges. I have had two in the last month where print quality is fine but when you copy a color print like say the maintenance page the lighter areas are non existant and the darker area are blurred or off color by quite a bit, sometimes the border edge that is the darkest looks ok though. That last one I had do this I swapped the whole top scanner no chance, replaced the board in the back the big one where the scanner plugs into with no change, tried xfer roller and new pcus no change (did that cause problem seem to start after pcu replacement) this one ended up with customer buying a new machine.
    Well now ive got another customer with the same issue and I am wondering if anyone else dealt with these having copy color issues, black seems fine only color shades are really off and only on copy if you print something its fine.
    Any thoughts
  • Counsel
    • Aug 2011
    • 529
    Re: spc 221 222 models small junk model copy quality issue
    A new CCD gave it about an 80% improvement but its still not great
