sc141 intermittent problems on mp2550sp
  • alliedofficeproducts
    • Jan 2015
    • 92
    Hello there. New to the site and was hoping someone may have some insight on a MP2550sp. Getting an intermittent sc141. Have tried replacing the sbu, ipu and checking harnesses and cables. The machine is in this state when customer arrives in the am and will happen during the day when not in use.
  • sandmanmac
    • 3983
    Re: sc141 intermittent problems on mp2550sp
    Only 2 other options: Either BCU or SIU
      • Jan 2015
      • 92
      Thanks! I will be trying those options Monday.
      • laitang
        • Nov 2012
        • 627
        Update firmware - system/copy may be solve your issue.
        • Dumus
          • Feb 2010
          • 79
          To begin with:
          Clean the glass with the bottom side (especially white band - then clean all the mirrors and lamp).
          If you do not help, then you can go on replace : BICU, SICU..............Let's god to help you.
          P.S. You must have to reset the SC code, before on machines.
