@ Remote
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    @ Remote
    could the @ remote make feed backs to a personal server or does it only work for Ricoh, in my point of view I think its possible, any help.
  • pspahr
    Toner Schlep
    • May 2008
    • 227
    YES
    I've set it up once about a year ago. You can direct the machine to report to a chosen server/destination or, using the pc client software you can log into the machine remotely and see the data. Unfortunately I lost interest in @remote shortly after that. Seemed real promising as you could clear most codes remotely and see alot of helpful info.
    As to how to do it look here for more info:
    You've probably already seen this info but just in case......
    VectorLinux---Check it out!
    • paulg
      • Jun 2007
      • 278
      When it first came out many were put off by the fact that all info went though servers in japan.
      It may have changed now
      • iMind
        • Mar 2008
        • 1116
        Yep, Thanks, thats what I was told too.
