Ricoh MP C2050, suddenly disappeared from the network
  • steele
    • May 2012
    • 48
    [Misc] Ricoh MP C2050, suddenly disappeared from the network
    Hi, MP C2050 worked fine until suddenly stopped printing. Evertything seems to work fine except that it is not visible on LAN. Machine doesn't obtain IP from DHCP but it's possible to set it manually. Direct connection to the network computer card also checked. Two LEDs in ethernet port are lit. I cleared NCS settings - no effect.
  • Zaxxon
    • 608
    Re: Ricoh MP C2050, suddenly disappeared from the network
    Ping the copiers IP address without networkcable attached, to see if there is another unit using the same Ip (common mistake)
    Please start you post with brand, model, problem.
      • 37446
      Disconnect the network cable from the MP C2050 and connect it to your laptop. If you do not get a connection with the laptop, then it is either the connector cable or the network, bad jack, bad cabling to the jack or bad switch. If the customer IT does not feel it is their network, ask them if they have another printer that they know is working that can be moved to there to test the connection.
      • StrippedScrew
        • Jul 2012
        • 58
        Had one do this a month or so ago, reseated connectors, wound up swapping controllers, new (previously enjoyed) one failed, reinstalled old controller, started working. WTF
        • steele
          • May 2012
          • 48
          Machine doesn't respond even to own "ping"...
          • TonerMunkeh
            Professional Moron
            • 3865
            Print off a confrig page. If "Ethernet authentication for IEEE802x" is active, it's locking the NIC out. Disable that and all should be spiffing.
            Hit it.
            • Sashko
              • Oct 2009
              • 110
              Disable SSDP protocol.
              • Polo-022
                • Sep 2007
                • 484
                I have had the same problem and this post gave me the solution.
                It was something beyond my knowledge...Thanks again, keep up the real good job, TM...
                • vga_man
                  • 78
                  is the machine obtaining it's IP address or not?
                  • qbert69
                    • Mar 2013
                    • 1152
                    I have had instances where SNMP caused non-printing issues...disabled SNMP and everything was hunky-dory after that!
                    REACH FOR THE STARS!!!
                    Konica Minolta Planetariums!
