Finisher problems
  • Bennybhoy
    • Sep 2014
    • 5
    [Error Code] Finisher problems
    Anybody come across this code on an MPC5503 SC721-70, customer getting p****d off as it only occurs now and again (cant spell intermittently)
    Suggestions would be most helpful
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Finisher problems
    I've got a 5503 with an SR3150 on it doing EXACTLY the same thing. Any ideas gentlemen / ladies?
    Hit it.
    • Gamut
      • Jul 2008
      • 216
      Try cleaning paper eject HP sensor.
      Don't ask why!
      Take top cover off finisher the sensor located next to stepper motor.
      I tend to clean all sensors in that area.
        • 37422
        • Zeldaman
          • Mar 2011
          • 946
          Hi there!
          Check finisher-fw, for the SR3170 it is version N now.
          Greetings...
          • Zaxxon
            • 608
            The metal bracket holding the finisher exit tray could be bend, blocking the traylift. Seen this a couple of times.
            Please start you post with brand, model, problem.
            • Haggy0310
              • Oct 2012
              • 7
              Totally agree with Zaxcon. Had this problem twice. Bracket on the shift tray has bent causing the shift tray to vibrate at decending. Check the bracket.
              • Iowatech
                Not a service manager
                • 3930
                If that finisher doesn't use the gray foam rollers at the exit tray, please ignore this post.
                However, if it does, make sure those rollers are in good shape. If they are worn out, the paper entering the tray will not be pulled under the stack height sensor's feeler. The machine will then will shut things down after it can't detect the stack height increasing.
                • mikelc2
                  • Feb 2015
                  • 10
                  I don't want to hijack and will post in a new thread if necessary, but has anyone seen an issue where the sr3170 doesn't jog 12x18 paper properly? The first page appears damaged, then all subsequent pages aren't jogged properly (although you can hear it jogging.)
                  • Cipher
                    It's not easy being green
                    • May 2006
                    • 1309
                    Check out the lower limit micro switch, lever and spring.
                    • T911
                      • Jun 2007
                      • 628
                      can anyone provide the lattest firmware to update the sr3140 finisher attached to the c5503. it sporatically is tripping the sc721-70 error. i did manage to here the lift motor once bind when i first found the height sensor lever clipping the wire harness. i routed the harness differently so the lever doesn't clip it anymore and i ran the crap out of it when i was there two days ago, but the customer just called back for the sc721-70 error again.
                        • 37422
                        If you are in the US and are a Ricoh family group dealer, you can download it from rfg-esource. Click the search button (not the search box), enter the product code for the MFP, in this case D148, for Firmware/Media type select SD/PCMCIA and click search.
                        Always download only the firmware for the correct doc feeder type. If it says Common in the description, it is for both. If it say SmartOperationPanel then it is for the SOP. If it says nothing, it is for the normal operation panel. There will also be two that say ALL, one for the SOP and one for normal. These contain all the main frame modules but not any peripherals, finishers etc.
                        • limo
                          • Jun 2008
                          • 103
                          check rd686006
                          • dan@ucprint.co.uk
                            • Mar 2015
                            • 2
                            we have had this problem when people are stacking boxes of paper underneath the catch tray
