Ricoh Service Manual discussion tour
  • PA3040
    • Jun 2014
    • 171
    Dear All,
    I would like to start a discussion about RICOH color machine service Manual in details, So I would like to start first one of Metis series ( MP C 2003SP).
    Your input of knowledge and experience in this regard is highly appreciated
    First I would like to start from SP mode SP2-005 to 2-473 (Drum)
    2005
    [Charge DC Voltage: Fixed]
    DC fixed voltage when Process control is off.
    001 Standard Speed: K *ENG [0 to 2000 / 1350 / 10-V/step]
    002 Standard Speed: C *ENG
    003 Standard Speed: M *ENG [0 to 2000 / 1350 / 10-V/step]
    004 Standard Speed: Y *ENG
    005 Middle Speed: K *ENG [0 to 2000 / 1350 / 10-V/step]
    006 Middle Speed: C *ENG
    007 Middle Speed: M *ENG [0 to 2000 / 1350 / 10-V/step]
    008 Middle Speed: Y *ENG
    009 Low Speed: K *ENG [0 to 2000 / 1350 / 10-V/step]
    010 Low Speed: C *ENG
    011 Low Speed: M *ENG [0 to 2000 / 1350 / 10-V/step]
    012 Low Speed: Y *ENG
    Please explain your experience pints when you are changing of above values.
    What is the operation of this mode?
    What are the key factors that we need to take in to account at changing this values
    What are the results that we can achieve,changing of above values
    What are the speed mention above?
    Thanks in advance
    • 37533
    Re: Ricoh Service Manual discussion tour
    These values are used to manually control the DC charge voltages when Process Control is turned off.
    • PA3040
      • Jun 2014
      • 171
      Dear slim,
      thanks for the reply
      Is it possible to stop process control and how?
      I invite to other members to contribute this tour
      • Cipher
        It's not easy being green
        • May 2006
        • 1309
        • It's not a good idea to disable process control.
        • No need to change such SPs unless instructed to by an Ricoh technical bulletin or part of a adjustment procedure.
        My 2 cent.
          • 37533
          SP 3041 used to be used to turn portions Process Control On/Off. SP 3041-001 selected whether Process Control or the manual settings would control charge and bias voltages. Sp 3041 is not shown in the Service Manual for the 03's. I have used it in the past to be able to lower the development bias to handle some minor image problems that process could not fix. One instance was a customer printing a newsletter for a hunting group. A picture on a page had a hunter on a hillside wearing a bright red hunting cap. The cap on the page was a little less than 2mm in diameter. The problem was that it was such an intense color spot that the cleaning blade could not fully remove it and it offset down the rest of the page, getting slightly fainter each time. By lowering the development DC bias voltage 50 volts, I was able to eliminate the offsetting. I have since been given the attached document by a regional rep that works by lowering the toner concentration in the developer and raising the transfer current to maintain the the same image density. Service Program (SP) Settings.pdf
          • PA3040
            • Jun 2014
            • 171
            Dear Slim and Cipher
            Thanks for your gate ideas.
            I would like to have more ideas before we move to next SP value.
            Dear Other members, your contribution on this tour is highly appreciated
            Thanks In advance
            • PA3040
              • Jun 2014
              • 171
              Dear All
              Can you please advice how may i adjust the customer expected color, using gamma correction using following SP valuve
              4909
              [Man Gamma:P ColK]
              001 Offset:Highlight *ENG [0 to 30 / 15 / 1/step]
              002 Offset:Middle *ENG [0 to 30 / 15 / 1/step]
              003 Offset:Shadow *ENG [0 to 30 / 15 / 1/step]
              004 Offset:IDmax *ENG [0 to 30 / 15 / 1/step]
              005 Option:Highlight *ENG [0 to 255 / 0 / 1/step]
              006 Option:Middle *ENG [0 to 12 / 0 / 1/step]
              007 Option:Shadow *ENG [0 to 255 / 0 / 1/step]
              008 Option:IDmax *ENG [0 to 255 / 0 / 1/step]
