Re: MP -301 bypass-jamming
And thanks for sharing this "find" Zeldaman
Hi there!
I love monday-mornings.......
Customer had problems to copy on thick paper, allways jam & a little scar on leading edge (A-4 paper). Take away the section with the roller & sensor (only 2 screws) and saw that the mylar pn B0442814 was not properly glued in. Left side OK, right side ca. 1 1/2 mm to high. Corrected this symptom, thick papers running fine.
Back at the showroom, i looked at the 301 standing there! Looks like the person who mounted this mylar was drunk or high ????
RICOH (germany) is informed. I will have a close look to other 301 in the field.
Greetings...Leave a comment:
Hi there!
Greetings...Attached FilesTags: None
