For the older models this was mostly caused by a loose or faulty RAM, try reseating all connections on the BICU. If the machine has a fax option make sure it is properly seated too.
It might also help to do a memory clear on Copier, Fax, Printer, and Scanner applications.
It appears even after all firmware upgraded, including java card I still got the issue advised to wind back the upgrade to the ringdale follow me software.
