Ricoh MP C3300 SC441
  • tibbs
    • Aug 2008
    • 225
    Hello, I have a Ricoh with an error sc441. Says its a motor overload. Can say which motor is the problem.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Ricoh MP C3300 SC441
    It tells you clearly in the service manual, ITB motor. If you do not have a manual then you should not be servicing these machines.
    • bob marley
      • Jan 2012
      • 1339
      Sc 441 is Image transfer belt unit( ITB ) motor error . it could be due to overload , the motor itself could be defective or IOB .
      Live for yourself and you will live in vain. Live for others, and you will live again
      • turbojetboy
        • Aug 2009
        • 279
        It will be torn transfer belt d1446091
          • 37475
          I have had bushings seize in the ITB and cause motor overloads.
          • Lustar32
            Transfer belt torn causing cleaned blade to flip and cuase heavy load on motor.
            • henrily
              • Feb 2018
              • 2
