Can you fit type 1027 pcu into a rich 2852?
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    If I do sp 2801and fit this pcu will it work?
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
    • 37532
    Re: Can you fit type 1027 pcu into a rich 2852?
    Read this thread http://www.copytechnet.com/forums/ri...52-3352-a.html
    • leo34staffs
      copierman
      • Aug 2007
      • 503
      Thanks for the quick response. The reason I ask is because the Dev gears have shredded on the 2852 and the cost of the Dev tank is expensive ( the gears are not sold separately). Unless the gears from a kir can be fitted?
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        The parts you need may be expensive, but when you go to the 1027 pcu your cpc rate goes up considerably.
        Mystic Crystal Revelations
        • fshead
          • 2376
          i havent worked on a 2852 but if the drum is the same as the mp2550 then i think you might be able to get the gears from katun..
          dont but their drums they are soft as butter and dont last..
          • leo34staffs
            copierman
            • Aug 2007
            • 503
            After inspecting the 2852 Dev unit the gears were worn due to Dev leaking in there. With a small mod I fitted the type 1027 pcu and this has worked. Thanks for your input.
            • semi
              • Sep 2008
              • 195
              The gears are available,have been for years and cost just over a quid
