Ricoh mpc2030 reset back to factory settings
  • Leebs14
    • Feb 2014
    • 457
    Hi all, how can i reset a MPC2030 back to factory settings? I need a starting point to work from?
  • Zeldaman
    • Mar 2011
    • 946
    • Leebs14
      • Feb 2014
      • 457
      Re: Ricoh mpc2030 reset back to factory settings
      where can I get the latest firmware from? (please dont say Ricoh as if i has access to that I wouldnt be on here)
      • Elmo
        • Feb 2010
        • 541
        You can reset some setting to default and format the hdd this will
        clear all user data using copy sp mode
        if you are wanting to reset the meter count i cant help
        I Used To Live To Fix Things Now i Fix Things To Live
        • ruben
          The New Guy
          • Oct 2012
          • 1203
          For the touch screen models you can go to User Tools, hold # and press on each option (System Settings, Scanner Features, Printer Features, etc) to reset to factory defaults. For everything else, you will need to go through manually and make a list for the future.
