Lanier LD040 (D011-17) Set-up Question
  • Claudio
    • Feb 2007
    • 235
    How can I disable the auto duplex setting. When copying, it automatically prints onto 2 sided. No option on the screen to print 1 to 1.
    Scrolled through the pdf service manual and not finding it. Also don't see it on the internal prints 5-990-All.
    I've been told they now come that way from the manufacturer, but how do you turn it off?
    Thanks in advance.
    Claudio
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    Thanks in advance.
    Claudio
    easy go to\ user tools\ copy features\scroll in there:
    General Features
    Duplex Mode Priority
    You can select the type of the Duplex
    function effective when the
    power is turned on.
    • Claudio
      • Feb 2007
      • 235
      Originally posted by iMind
      easy go to user tools copy featuresscroll in there
      We've scrolled the copier menu as well and did not find it.
      Do you have exact specifics where in the menu it is at?
      Thanks again.
      Claudio
      • iMind
        • Mar 2008
        • 1116
        Thanks again.
        Claudio
        duplex one to one
        • cobiray
          Passing Duplication Xpert
          • Mar 2008
          • 1199
          On the main screen de select the duplex mode. Then press the program button (top right), then select set as default, then program, then yes.
          • Claudio
            • Feb 2007
            • 235
            Hello Cobiray:
            Thanks for your reply.
            On the initial screen, the display does not offer 1 sided to 1 sided. That icon is not there. The only duplexing icons are 1>2 T2T, 2>2, 1 comb 2 orig, 1 sided comb 4 orig,..
            How can I get the 1 sided to 1 sided icon on the screen and to defualt to 1>1 copying?
            Thanks for your support.
            Clauduio
            • Claudio
              • Feb 2007
              • 235
              I am not able to deselect from the duplex mode since all copying choices lead to duplex copying.
              • iMind
                • Mar 2008
                • 1116
                In user tools copy & document features there is a one to one duplex mode, I´ll upload the user manual.
                this is your link:
                just open the site in full screen and close the add and your download will pop up on your bottom left.
                • Claudio
                  • Feb 2007
                  • 235
                  iMind:
                  Thank you for your support and time for uploading the Aficio 1035 user manual.
                  The Aficio 1035 has product code B003, but the Lanier LD040 has product code D011-17.
                  There may be a diference and may be why I was not finding what you were referencing. Will look through it.
                  We are still researching this, but if anyone knows what I need to do, I would appreciate it if you let me know.
                  I'm starting to think the answer is in placing the 1>1 icon into the initial screen and then deprogramming duplex default.
                  Right now we just don't know how to get the 1>1 icon into the initial screen.
                  Claudio
                  • iMind
                    • Mar 2008
                    • 1116
                    iMind:
                    Claudio
                    what machine is that? cross reference it on precision roller but could not find it, all the new GW machine are almost the same, I can look it up tomorrow anyway, but Im certain its in the user tools\ general settings 3rd or 4th page.
                    OK, sorry maybe you right, looks like MP 4000
                    • Claudio
                      • Feb 2007
                      • 235
                      It crosses over to a Ricoh MP-4000
                      • iMind
                        • Mar 2008
                        • 1116
                        User tools\copier document features\ select Customize Function key "OFF" its the first button next to the 2 single side original to 2 side duplexing.
                        just set it to OFF, LOL shit why does the easy ones become the hardest, we not reading, hehehe
                        • Claudio
                          • Feb 2007
                          • 235
                          iMind:
                          Thanks so much for your help.
                          I will look into the info. you sent me 1st thing in the morning and will let you know what happen.
                          Have a great evening.
                          Claudio
                          • cobiray
                            • Mar 2008
                            • 1199
                            Just so we understand, the main copy screen has the single side original to duplex copy selected (highlighted). If you press the touch panel again it will unselect the mode thus giving you single side to single side copying.
                            If you can't unselect the mode on the touch screen you may need to run the touch screen adjustment.
                            • Claudio
                              • Feb 2007
                              • 235
                              Finally corrected
                              Good morning guys:
                              This morning we received a call for tech support through the distributor we purchased this machine from.
                              He had us go to the initial screen, deselect 1>2 so that icon is not yellowish, press the program button, set program default, yes, then resets itself, then he had us power the machine off and back on.
                              It appears you guys were right on. Either we were just not getting it right or the powering the machine off and back on was the step we were missing. I still need to find out if that is the case. I will enter it in my technical note for future reference.
                              I greatly appreciate your support & valuable time, and this web site.
                              Have a great weekend.
                              Claudio
